View the thread, titled "ideal vogue excess air problem" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
PlumbBobBob
I have a customer who had a vogue fitted in march, not by me, which is suffering from excess air in the system every morning. the only thing that has been changed on the system, microbore on manifold, is doing away with a radiator because they now have a log burner in the lounge. can anyone think why this is happening every morning? the boiler comes on as normal then clunks and bangs and shuts off, cust then runs the auto venting on the menu and the boiler runs as normal.
could it be because there are two dead legs on the manifold?
no, no pressure drop at all
thinking on it a bit more, could be one or more rad valves they are all original 15-20 years old
I'am just throwing some Ideas around as I have a very similar problem on a job, I think pin hole on the return or radiators have a corrosion problem.
system is all copper microbore on a huge old manifold. don't know if it was flushed or not, but inhibitor is in as I put it in when I changed a couple of rads for towel rads. going back on Monday to attempt to get to the bottom of it.
right then got to the bottom of in the end. it was one of the rad valves leaking from the top added to which the microbore had a Yorkshire converter up to 15mm for the valve which was hardly soldered at all, surprised it held the pressure back tbh. all good now.
This is what i'am going to investigate on my next job, got a similar problem with a heatslave.
Did the system lose pressure with you steve?
Reply to the thread, titled "ideal vogue excess air problem" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
