And it involves a drain-down.
And you make sure boiler is working before you start.
You turn off boiler, turn off power to pump.
Drain down.
Do the work.
Fill up, add inhibitor, remove any airlocks present.
If the boiler then won't work / work properly on re-starting system - is it always fair to say this will be because of an inherent fault that has come to light or at least a co-incidental fault that may have decided to develop during a drain-down but is not something I could be claimed to be responsible for? So in either case - not my fault?
I've only had this happen once. Got a guy out who said the fault was a random co-incidence and explained such to customer. But in total I've done maybe 9 or 10 drain-downs and re-fills on my own. Not many. And so it's always a background worry since the occurence. But is it basically the case that as long as I follow the correct above proceedure (and don't hit the boiler with a spanner or pour ketchip into the f+e) no fault that occurs could ever be my fault.?
I'm not asking because I'd want to cut and run. I'll happily help to get a boiler engineer out to have a look and try to be there when it's looked at - it's not an issue about time.
I just want to know there's not something that could go wrong that I could reasonably be blamed for... and then have to spend £200 on 😡
Drain down.
Do the work.
