R
Rotax100uk
Hi all, the immersion tank we have has two heater elements, one economy 7 at the bottom and booster at the top, both controlled by switch fused spurs on the wall etc...
We are getting alot of noise coming from the tank (LOUD banging sounds) the set temp of the stat is 60oC.
Firstly i have been told to check the thermostat, so i swapped over the top and bottom stats..... still no difference!!! (both set to 60oC)
We then got in touch with a local plumber who said "why is the stat set SO HIGH!!! it should be set to 40oC"
So i am understanding, the stat needs to be set to 60oC to stop bacteria growth.
By the way we are in a hard water area, with no water softners
Can anyone offer any better advice as its becoming hard to sleep with all this noise (Tank is in the main bedroom cubboard)
