Strang
Afternoon all, and thanks in advance for your help.
About 2 years ago, the immersion heater in our hot water cylinder broke so we had it replaced. Now I can't remember 100% but I'm sure that before the change, when we put the immersion on it didn't make much noise.
Since the change, as soon as you put the immersion on, it sounds like a kettle - a kind of hissing/bubbling noise that a kettle makes as soon as you switch it on - and this continues until it reaches its 'completion' and then it turns off.
My questions are:
1.) Is this normal and am I just mis-remembering the old one?
2.) If not normal then what could be going on with it and what can I do to change it?
Other factors which may/may not be a factor are the system I have- solid fuel Rayburn heating the hot water (and radiators). We don't use the immersion when we are using the Rayburn.
My questions are:
