View the thread, titled "Immersion heaters are a pain in the rear." which is posted in UK Plumbers Forums on UK Plumbers Forums.
Millsy 82
I've got a problem with immersion heaters just keep randomly tripping even though they work perfectly 99% of the time and even on brand new immersions that I have left to heat up and checked the temperature.
They keep going on the thermal cutouts which are built in, I swear they are just not fit for the job and it makes you look like an idiot going back to reset them.
Some people hang clothes over the heaters covers & the cut out gets too much heat & cuts off power.
Thats why some heater covers have the words Do not cover, stamped in them.
Also might overheat if another source is heating cylinder.
What are they meant to cut out at? Most of my cylinders I set to 55-60 and they still trip.
Good point about hanging clothes over them.
Tbh, I am not sure. Without looking it up, I assume they cut out at close to boiling point, but really could do with cutting off at much lower temperature. Edit, - just read that they cut out at 95 or 98 degrees.
The heat builds up inside the heater cover. I had it happen with the white thermostats & I had to lower the max setting on the stat to 55. Maybe you need to try a different brand.
Getting off the point a bit, just wondered do you ever see Willis external heaters? Think they are largely mostly fitted in this part of the UK.
1 unvented on a megaflo. 2 vented different brands. Whatever plumb center and Williams sell.
All I do is go and reset and drop the temperature a little bit but on the megaflo they have said the water isn't got enough and it's set on about 3 and still tripped again.
I haven't a clue what stats are going in mega flows these days , you are right they are a pain , the closer the two temps are the worse the problem is , but this sounds like it's the high limit stat rather than the control stat. When you say they are built in , are they the type that have 'flats' on , and look like they come out with a spanner, because it might be worth trying changing them rather than an expensive drain down and a new immersion heater
Can anyone recommend a reliable immersion heater as I have 1 gone down yet again! So I went out and missed the first 10 minutes of the rugby (shame it wasn't all of it) and now the customer is saying the water isn't hot enough after resetting and it's been 3 hours!
I may be wrong, but I think they are pretty much all made by Backer or Thermotec, regardless of what it says on the label.
Sorry it's the stats keep tripping. But I can't keep going on every 6 weeks going back and resetting them! If they are new they should work! Simple as that really isn't it.
Cheppo immersion heater stats are bloody useless, believe you me I have had no end of trouble with them , the backers are alright ish, I have loads of trouble with cotherms, it's all because they are cheap, why a manufacturer doesn't make a decent quality stat and charge accordingly I will never know.
Unless somebody can tell you / me otherwise the only decent one made was the sunvic vk range not vkl, think I have got that the right way round.
I had the same issue a while back, it turned out to be ambient heat in the airing cupboard causing it due to too many clothes and a lack of ventilation. Ask you customer to leave the airing cupboard door slightly open and remove any clothes/towels etc which are very close above the cylinder to prove this.
Credit where it's due I've just phoned backer technical and they said they will send a new stat out.
Lol, don't hold your breath pal, I have swapped two today , I fitted them this time last year .
Reply to the thread, titled "Immersion heaters are a pain in the rear." which is posted in UK Plumbers Forums on Plumbers Forums.
