View the thread, titled "Immersion size - help" which is posted in UK Plumbers Forums on UK Plumbers Forums.
O
Old Account
Hi lads,
just wondering if if anyone could could tell me what size immersion I need for boost and off peak ?
Current immer name Heatre stadia / superloy 2 - 2.3/
What would you guys do regarding the asbestos gasket ?
Also the bottom wire were burnt ...
kind regards
ron
3kw immersion needed and replace the flex with heat resistant flex of 1.5mm and make sure the connections are screwed up tight.
Hello Stani,
You mean 1.5mm heat resistant wire ?
I will leave this to the electrician who will come anyway as he completely connected the economy 7 wrong.
However, regarding the seals which are asbestos ... just take them out in a safe back ? Where shall I dispose those ones ?
Thanks for your help
Kind regards,
Ron
Hello Stani,
Kind regards,
Ron
Plume centre doing incoloy, Tesla TIH540 on special offer £16.79 .
Hello Stani,
Kind regards,
Ron
Yes, wire/flex 1.5mm will suffice but make sure it is heat resistant, the bit between your fixed cables to the immersion is wired in a flexible cable.but your sparks should know.
Regarding the gasket, I'm not sure I remember these being asbestos, but for the size I would wrap it in a bag and dispose of as you see fit.
Reply to the thread, titled "Immersion size - help" which is posted in UK Plumbers Forums on Electricians Forums.
