For the life of me I can’t work out how to fit our toilet seat. The builders obviously couldn’t either and used silicon that has now come loose. All I can imagine is it needs a nut fitting with a barb that expands after the bolt is pushed into the base but I’ve never heard of such a thing. It’s beaten me so would love to know! Thx
The rubber piece is the barb
clean everything up eg remove the silicon
undo the centre screw so that the rubber barb is loose push the barb into the hole
tighten the screw
You need to clean and degrease the blind hole and the fittings otherwise as the rubber bung expands it doesn`t bind/ grip inside the hole. Google blind hole fittings and consider replacing if it doesn`t work after cleaning.
As above, clean all the crap off and insert the bung after loosening. As you tighten the screw , the bung expands
Genius, thanks very much!
[automerge]1594131936[/automerge]
Really, kind and much appreciated. Thank you.
[automerge]1594131979[/automerge]
tighten the screw
Brilliant, now why didn't I think of that?! Thank you!
