A
Aidex
Hi Everyone
A friend has just had a new boiler with an in line descaler fitted to his incoming cold supply after the stopcock. As we're getting all new plumbing he said we should get one.
First thing, do these things work/are they worth it?
My real concern is that it will reduce flow rate. We've just had a new 25mm supply put in which we want to run into a (to be fitted) unvented cylinder (in 25mm). The in line descalers I've found online are 15 or 22mm so that would mean reducing the new supply to 22mm. Can you get descalers in 25mm or should we put it somewhere else? Having paid for a new supply to have increased flow I'd rather not reduce it just for a descaler.
Thanks for your help!
A 😉
A 😉
