J
jdstratton@btin
I have recently purchased an 900 x 450 Indirect RM Copper Cylinder from Plumbfix and note it has a Coil Support fitted inside the cylinder , it looks like a plastic material with half holes cut and sits on the bottom of the cylinder then the half holes are supporting the coil . Just a flat piece of material .
Probably a daft question but this is the first one I have fitted for some time and have never noticed this before , my question is : Is this fitted for transit purposes only or am I correct in assuming that it stays in position acting as a support for the life on the cylinder ? It would be awkward to remove if it does need to come out so hopefully it stays there .
Many Thank For Any Replies .
John
John
