3 bed 1900s house , ground floor is concrete floor, requires 3 or 4 medium size radiators, rather than chanelling the concrete floor with 22mm copper central heating pipes (via a duct or sleeve pipe to satisfy building regulations, would it be ok to run the ground floor 22mm copper pipes using the same 22mm copper pipe running in between floor joists on the first floor's 3 radiators, and create Tee off drop downs connecting to the ground floor radiators? is a pump required? anti gravity valve? I hope to have a combi 28k combi boiler installed
lastly, if i chanel the concrete floor, what is best for anti corrosive and for insulation of 22mm copper pipes carrying central water?
denzo tape (if the boiler goes crazy, will it withstand 65+ deg to over 90?)
vs hessian felt sleeve/horsehair
vs climaflex insulation pipes
vs kuterlux plastic coated copper pipework
vs pipe duct from travis perkin
Thank you for your invaluable help
Regards
Paul
Regards
Paul
