View the thread, titled "Installing a mains pump" which is posted in UK Plumbers Forums on UK Plumbers Forums.
A
andy44
Hello all
I am thinking of installing, getting a plumber that is, a mains pressure pump from screwfix to help with reduced pressure during certain times of the day/year and improve the flowrate. I have a water meter which was installed 16 years ago. I suppose most/all of the neighbours will also have water meters installed. I think these meters have a one way valve to protect neighbours and I am protected from inadvertently pulling their dirty water. If that's true I can install one or more of these pumps with no problems?
Am I on the right track? I have not called up any plumbers for advice and costs yet, wanted to know if it's doable first.
Andy
Do you have an unvented cylinder?
Yes the old storage tank in the loft was disconnected many years ago and it is still there empty.
I was worried that if I fitted a cold water mains pump it might pull dirty water from other houses.
And on second thought I am thinking that houses higher up on the hill may already be fouling my water ? I do have very good drinking water filters but still.
Am I being too paranoid?
i would start by asking does anyone else in the street have the same problems? then get the water supplier to check the incoming main if theres not enough water there a pump will not help
Yes they do, and what's worse we live on a hill so the ones at the top are affected the most. I am not at the top but still way, way above the valley.
Do you think it is possible that with a pump I might get backflow from the houses above me on the hill? Is that possible?
So long as you still have positive main pressure in the highest part of hill I'd say no.
But in the event of a water main failure if someone at the top and bottom simultaneously opened a tap then who knows lol depends how old it is and if they covered all bases when the street was built ?
You can easily get a plumber to fit a back flow prevention device.
You may also have to get permission from the water undertaker (supplier) to fit a pump on your supply coming in off a main.
There are limits on what they allow pumps to flow litres per minute.
Have you not considered a large (depending on your needs) break tank at the highest point in you property (loft)
Reply to the thread, titled "Installing a mains pump" which is posted in UK Plumbers Forums on Electricians Forums.
