View the thread, titled "Installing dog bath in basement. Waste is 1 metre higher then bath." which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
Mervyn
Hi.
My daughter is installing a Dog bath in the basement of her new dog grooming shop but the waste pipe is 1 metre higher up then the bath. Is there some kind of pump we could install. We are on a budget so the cheaper the better.
Kind regards
Mervyn
Hiya
Dont install a plumbed in pump such as a 'saniflow' the dogs hairs etc
will just block it up.
I would install a large 2nd hand pressed steel bath - plug all the holes
overflow, waste etc. and then go to machine mart or other and purchase a small portable submersible pump with a lift of 4m or so - pump out to the upstairs drain system and off you go.
centralheatking
I would opt for a whale pump. They are easy to clear and are designed for this purpose. Any submersible pump will be a pure hassle and you will never get the bath empty with it unless you leave a plug in and drop the last of it into a basin.
Whale pump mate way to go.
I'm with oldplumber here. Cheapest option is to borrow some steps OR just hose them down.
Why not design a mouse type wheel. so the dog can pump out the water. It would get punters talking and be a good marketing ploy. TV, Radio and front page of the Sun.
wash the dog freeze the water then take it upstairs ,the water not the dog.but it would be ice not water, also you would have to take the dog upstairs eventually, i tell you what tell her to move to other premises.
Hi On a more serious note. If you decide to pump it ? Dishcharge over a gully rather than into a stack at low level. If the drains block you could end up with a basement full. I would not trust NRV"s with waste being pumped.
Reply to the thread, titled "Installing dog bath in basement. Waste is 1 metre higher then bath." which is posted in UK Plumbers Forums on Plumbers Forums.
