View the thread, titled "Instead of PTFE tape ?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
E
easyt
I will bw fitting a Mira shower. These have a Z connector with 1/2 inch BSP on one end to fit a supply elbow and (probably) 3/4 on the other to fit into the mixer. As it is a Z connector designed to allow for differing supply pipe centres can't just use PTFE and tighten up as the ends to the mixer have to finish at correct centres. That means using some sort of fluid jointing compound. Any suggestions.
Easy T
I would use loctite 55, not a liquid but you can back off the thread if needed
might be wrong here but the adjustable centres work using o rings normally, why do you need ptfe etc, especially a liquid jointing compound which if you read most shower manufacturers instructions are verboten as youll block the cartridges etc. best to read the mfi and check your not barking up the wrong tree
only my opinion but you only need to use ptfe on a threaded fitting, olives work ok on their own if put together properly, why use ptfe, only looks untidy
Manufacturers Instructions oldplumber are 'Apply suitable thread sealant (not supplied) and attach the offset connectors to the pipework in the wall. The offset connectors must protrude between 35 and 40 mm from the finished wall.
The connecting thread from the mixer is a 1/2inch male BSP thread. This has to be rotated to align provide the correct centres. (Damned silly idea I reckon. It allows for pipe elbow centres in the wall between 174mm and 126mm).
Sounds like the Loctite 55 Might do the job. Thanks
Easy T
Would Loctite 572 also be an option ?
Would ptfe tape let me fasten up and then back off to get alignment. I have used ptfe tape often but not sure of ius full abilities for realignment oldplumber.
EasyT
carefully try it and see, get your alignment right before you tighten right up
That's the problem oldplumber. The alignment is controlled purely by how far you wind the male bsp into the female on the elbow. It is not a freely moving coupling that you can align and then lock up.
Can't post the image on here as it is on pdf and too big,
http://www.mirashowers.co.uk/onlinecatalog/pdf/atom_diverter_iug.pdf
That is a link to a similar setup.
looked at loctite 55. That lets you tighten up and back off up to 45 degrees. Problem is I might have to back off nearly a full 180 degrees in worst case scenario. Looking like a setting liquid maybe.
You can always go to your plumbing merchant and get some straight fittings, i regularly do, some real good quality ones complete with chrome caps to hide the housing for about £15. I agree that the "z" fitting is a good idea in theory but in practise it is nowt but a pain
good luck😀
contact mira tech dept. they may have a solution to your problem that is not in instructions supplied with unit as I am sure you are not the first to have come up against this problem good luck regards turnpin🙂
I fit all bar mixer showers on a "Shower Plate" and throw the z fixing in the scrap box or use the fast fixing with cover sheilds, tidy job and sturdy fixing ..
I have just the same problem. Pipes are rendered in and 160 mm between centres shower is 150 mm between centres. No option but to use the 'Z' connectors.
I have tried 3 times now to get things just so but have always ended up with one seal or other weeping (currently the hot is shedding about 1 tear drop every 6 hours or so).
That is with PTFE tape. I wonder if there are any tricks or tips? Over 'bandaging' seems to help but most surplus squashed out anyway. I plan on trying gas PTFE (thicker) or loctite 55 next. Really need a way to take up quite a lot of play between the threads.
Doesn't the shower end up on the **** unless the z connectors are in line with each other. Backin off ptfe usually leaves a leak.
i always get it set up right in first fix remove shower and the protect with paper and masking tape while its plastered and tiled i only use 55 now wonderfull stuff
Yup that's exactly the problem 🙂 Even if you don't back off (edge each one into position forwards only) you still can't tighten the whole way as once everything lines up you need to stop.
What is 'SS' ?
eems like a good idea Spudhater
Hi. If the female fitting in the wall has a shoulder at is thread depth? Have you tried a red fibre washer (as on tap connector) or two, put in female against shoulder and then screw in male z fitting.
start with the connectors level but wider tha the shower centers ,cap and test then once tiled tighten both equaly to the right center
youre the one at the job mate - i always use a little tube of "L.S.X." - Toothpaste tube size 5quid, so quite expensive, but its an amazing threadseal gel type substance - that explodes into hard sealed waterproof plastic if touched by water . . . dont wear nice clothes as it ruims t - guess what,? never had a leak yet with it!!! ( worded that well didnt i? -regards moore
See " Shower PL8" 150mm centers
Thanks all. I have picked up a shower pl8 from local merchant Spudhater. Didn't haggle as I thought his price £20 was OK and his price for the main items was very good compared to other suppliers locally. (Also a pleasant, helpfull guy to deal with).
I once bought a tube of 'liquid ptfe' it was good stuff. Not good enough to buy twice. but perhaps thats the product you're after?
Hi DannyP.
I did consider a similar product to the one you describe but considered that, at the end of the day, it was a well to ditch the Z-connectors.
Not an option for me as the pipes are set into the wall at 160mm centres and the shower mixer has (standard) 150mm centres 🙁.
Reply to the thread, titled "Instead of PTFE tape ?" which is posted in UK Plumbers Forums on Plumbers Forums.
