View the thread, titled "Intergas System Boiler Condensate Trap Protrudes Below Bottom Cover" which is posted in Boiler Advice Forum on UK Plumbers Forums.
R
RichardMon
I am just installing an Intergas Compact SB40 boiler but the condensate trap protrudes about 15 cm below the bottom cover. It is unsightly and frankly a design nonsense. The other boilers in the range are all smaller and the condensate trap is also smaller and is concealed by the cover.
Do you think I could get away with fitting a smaller trap? The alternative is raise the boiler and drill another hole for the flue. Grateful for any ideas.
I'm no GSR & have limited knowledge on the subject but I would hazard a guess that there's a reason it is the way it is. Sometimes these things just really aren't messing with.
But that's just my uneducated opinion.
Sent from my iPhone using Tapatalk 2
Why would he consider lifting the boiler?
Sounds like he hasn't left enough space underneath for the condensate trap to fit.
That's bloody expensive for a bit of bent sheet metal that should've come with the boiler!
means if you dont need it you save money, and I dont pay that much for them anyhow
Reply to the thread, titled "Intergas System Boiler Condensate Trap Protrudes Below Bottom Cover" which is posted in Boiler Advice Forum on Plumbers Forums.
