L
Lancashire Lass
This past week we've started getting problems with intermitten hot water supply from our boiler. It's an Alpa C23 combi boiler. Sometimes we open the hot water tap and the water heats up nicely within a matter of seconds and then all of a sudden, mid-flow, the hot water will run ice cold and remains that way. We've checked the indicator neons on the boiler when this happens to see if there's any fault being reported but the indicator neons are all lit the way you'd expect them to be and showing nothing untoward.
If we turn off the hot water tap when it happens, leave it for a minute or two, then turn it on again the water will run hot again within several seconds.
Any ideas what could be causing this to happen?
