H
Hannah73
Hi,😀
Forget I'm female, just help me out, guys, much appreciated!
I've got a diagnostic query- Gravity hot water system to a pump for upstairs hot water only. The owner reports intermittent fluctuations in pressure. There are no changes in pump noise when this happens. We thought it could be a foreign object that keeps blocking up at a certain bend or slight narrowing in the pipework. Flushing the hot feed from the cylinder to the pump hasn't worked, no visual signs inside the cylinder either. The pump seems to work straight away and continues when water on. Next thing is to change pipework from the cylinder to the pump which is now copper with a few 90 deg elbows. If no joy, thinking about perhaps the cold feed pipe. Any suggestions??😕
