View the thread, titled "Iron pipework" which is posted in Gaining Plumbing Experience on UK Plumbers Forums.
Hi
I need to T into an iron pipe. Both sides of the proposed T are attached to stuff that will prevent the pipe being screwed into a fitting, even if I get the tools to thread the pipe ends.
How do you connect into this stuff? In copper it would take 30 mins.
sorry dont understand what your saying?
I have some cast iron piping in my (40 year old) heating system.
I want to install a new radiator.
I need to connect into the flow and return pipes and they are 1" iron pipe.
How do I do it? I can't just cut it and fit a compression T because as far as I can see no such fitting exists.
The existing fittings on the pipe are threaded.
I can't fit a threaded fitting in the middle of a pipe - even if I can thread the pipe.
As far as I can tell, nobody has added anything to this system since it was built around 1980.
right ok
decided where the tee is going
cut one side correct to length and thread using a stock and die
for the other side cut 4-5" more off you can go more if this helps eg 10-12" and install a union so you can thread the new piece into the tee
hope this helps
right ok
hope this helps
Excellent thank you.
Pipe union - never thought of that - obviously never needed one on copper.
Another order for stuff the local plumbing Centre have never heard of coming up!
Another way might be to take out the iron section between two iron joints then use iron to copper fittings with an intermediate length of copper pipe. Again use the BES catalogue to decide what you need as it includes engineering type drawings alongside the fitting and price
centralheatking
Or employ the services of a heating engineer and take take the missus out for a pub lunch will be done by the time you get back home 😛 kop
Reply to the thread, titled "Iron pipework" which is posted in Gaining Plumbing Experience on Plumbers Forums.
