Do or DIY
I'm fitting a new kitchen and the existing 15mm cold water feed pipe that supplies the dishwasher now comes up exactly under the corner of the new unit. The pipe is about 6 inches (remember those) proud of the tiled floor with a dishwasher connector. The floorunder the tiles is concrete and the pipe is embedded in that.
Is it safe to remove the connector and bend the pipe a little bit whilst it's in situ. I reckon it needs to bend approx 20 degrees to the left then the connector will be free of the cupboard. Otherwise it means cutting the pipe and reconnecting it closer to the floor - but I'm concerned it will be a bit stubby.
I've got a pipe bending spring but I don't know which is the best thing to do. I'd like the easiest option (which I reckon is bend it) but I don't know if it's a sensible thing to do.
Any advice welcome 🙂
