P4ULT
hi all
as above rally its glued on is there any way to remove it?
paul
paul
I have got them of combination of levering of with sharp screwdrivers chisels etc and a grinding disc in the angle grinder to clean upt hen sandpaper time some times your lucky and it peels of in one bit some times its an hour getting it of in small pieceshi all
paul
might be worth trying to get the reducer out first then if that fails move on to the boss then when that fails two fernco rubbers and a boss lolits for my parents so no price either way how likely am i to gety success with a heat gun the stack is only a couple of years old need to change the from 3/4 to 1 1/4 for condense. moving it is not viable really not enough room.
not enough room im gonnab have a go at removing it.Can't you just plug it and put another one lower down?
Reply to the thread, titled "is it possible to remove a strap on boss" which is posted in UK Plumbers Forums on Plumbers Forums.
