M
muller
I have a vokera boiler with a drayton mid way valve to choose either h/w or c/h or both. When valve is set to c/h everything works fine but when valve is set to h/w the vokera boiler cuts out after running for approx 3 minutes.
Is the coil blocked or has it got an air lock?
I had a plumber fit the new drayton mid way valve as the previous valve started leaking. Since the new valve has been fitted, all i hear now a trickling noise in the water cylinder and also in the bathroom radiator when the valve is set to h/w.
Ive been told the coil might be leaking or blocked. There is no water dis colour from the hot taps.
If its any help, the radiator in the bathroom used to get hot when h/w or c/h but now only gets hot with c/h.
I was informed by my plumber that it should get hot on both settings which is what it used to do
Any ideas or help will be greatly appreciated. My heating system is a sealed system.
