O
Old Account
Just walked few days ago and seen this one here. Seems like somebody likes free gas 🙂 or am I missing something?
£37.00. What a rip off. I’ll do it for £30😛So I think the answer is no it’s not but when stuff like this is available readily. What the hell do you do????
Gas Meter Test fittings | eBay
Gas safe would do nothing,however the supplier would be all over this as its theft of gasIncredible, it will probably be a waste of time but I would report them .
No idea, i don't know how a plumber would move a metre, I'm just trying to stay positive about humanity 🙄Away from the regulator?
Good luck with that.No idea, i don't how a plumber would move a metre, I'm just trying to stay positive about humanity 🙄
Unequivocal yesWould this have been a justifiable occasion to ring emergency services and say there is a very strong smell of gas coming from that house?
Then sit back and watch what develops.
You are surely right about the disc. Could you just disc that off? If they changed the meter already they may know when it’s disc off. Perhaps it’s ap,umber too 🙂Yes agreed , not GS’s problem . The gas supplier needs to know , but whos the supplier ??
To blatantly steel like that just boils my ****.
I would go put a disc in that .
Also too, no handle can be very dangerous. It’s already dangerously fitted as it’s not been done by an expert. Furthermore no handleI suppose you could report it as illegal gas "work". As I can not see any legitimate engineer fitting the bypass. So technically it could be of interest to gas safe.
I contactedI’d say they should’ve been out by now I’d say it’s an emergency
I don’t know why you disliked but fair enough. I did say I contacted a company for gas safe theft and mentioned about the urgency.I’d say they should’ve been out by now I’d say it’s an emergency
I contacted them now. Within the next 4h someone will be going thereDidn’t know I had. Removed
Ooooo the tension mounts.......I hope you are sat 100 Yard away with a pair of Bino's Matchless?I contacted them now. Within the next 4h someone will be going there
Reply to the thread, titled "Is that leagal? ....." which is posted in UK Plumbers Forums on Plumbers Forums.
