View the thread, titled "Is that right to add inhibitor in boiler filter?" which is posted in Central Heating Forum on UK Plumbers Forums.
UK
I had an engineer today added inhibitor in the boiler filter via Magnaclean when he did the boiler service after taking off the filter.
But before the engineers all added inhibitor in the radiators, and I searched online that majority information shows the inhibitor should be added in radiator.
So is it ok or right to add inhibitor in the boiler filter via Magnaclean?
Thanks for any input!
Basically if you have a normal system it doesn’t matter where you add the inhibitor into the filter is and easy one as it’s empty after after he cleaned it into a radiator he would have to drain some water off the radiator unless he was using the pressurised type of inhibitor. It doesn’t matter where you add it as the water mixes in the system
Reply to the thread, titled "Is that right to add inhibitor in boiler filter?" which is posted in Central Heating Forum on Electricians Forums.
