Is there a gas engineer full tool bundle I can buy?
View the thread, titled "Is there a gas engineer full tool bundle I can buy?" which is posted in Plumbing Tools on UK Plumbers Forums.
Hi, I'm about to start a gas engineering course and I'm trying to buy all the tools beforehand. Does anyone else know if there's a full tool kit available from anywhere?
Course it is. It's not easy but no one should be gifted anything hence a recruitment process. Paying for these short courses means there is no selection so no competencies are tested prior to the course
I told them I was incompetent before I started, but they were ok with that and set up a monthly DD. 🙂 And my course took about 5-6 months.
I was just wanting to know if anybody knew of a bundle for sale anywhere. Like a starter one I could add to.
If you want to buy something, I mainly use pair of Bahco pump pliers and a small yellow and black adjustable. Use them on pretty much every job. Every plumber also has a r`berger superfire too.
But did you have any Plumbing experience B4 doing the gas ? as the OP has no idea at all of systems, and says he just wants to work on boilers & cookers
yeah admittedly I`ve had a number of years experience and also previous gas training.
I hope the OP keeps us updated on a regular basis has to how he is progressing through his course, maybe every couple of weeks, could be useful for other people thinking about taking this route, Not sure what the requirements are now for joining Gas Safe, but would they deem a 7mth course as enough experience to work on gas ?? question for you younger guys to answer ! what is acceptable to Gas Safe ?
Ive been told by the staff that once I have my cert in my hand, I can then ring/email Gas Safe, pay the £20 and become registered. I hope its that simple!
And you failed.
Says something about the whole setup, doesn't it, where a company can charge you thousands to put you through an exam in which you get two written attempts and then a verbal attempt, and still fail it.
No criticism of you, just the company that led you up the garden path with hollow promises.
I'm an experienced plumber, got my C&G in '82, but I had a real problem with Gas Safe and had to resit the whole course after a 20 year break. I found it difficult, but not an insurmountable situation, and, should you pass, there are numerous ways to gain experience, including working for free alongside a GSR engineer. As you have a weekend job, you might be able to do this but just be aware that there are many pitfalls along the way, and don't expect to earn that much in the first 3 -5 years. I went the self employed route and after 4 years I'm now starting to show a reasonable profit, although I couldn't pay a mortgage with it or pay for my Harley to be serviced (I do that myself anyway).
As for the tools - the list is endless I'm afraid but a good starter kit is available from Screwfix at about £100, all wrapped up in a handy wheelie type case.
http://www.NoLinkingToThis/p/tool-kit-aluminium-trolley-case-161-piece-set/8375j
It even has room in the bottom for a few other things that I use daily such as my pipe slices, water pump pliers etc.
I bought it in order to tidy up my van, and because I liked the fact that it's called Kendo (I teach kendo) but it is a good starting point although you will need some bigger spanners, a decent multimeter, Manometer etc etc
Good look with it all and don't listen to the nay sayers - make your own path and just keep going.
Someone in this thread already said it - Even the experienced started somewhere (Or something like that) 🙂
Reply to the thread, titled "Is there a gas engineer full tool bundle I can buy?" which is posted in Plumbing Tools on Plumbers Forums.
Abgash,
Robert Tyrrell,
