Isolating hot water supply - indirect unvented cylinder system
View the thread, titled "Isolating hot water supply - indirect unvented cylinder system" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
Hello,
I am fitting new taps and a shower mixer in my en-suite and was looking to isolate the hot water pipes. I have an unvented indirect heating system (have attached some photos).
I was wondering if the isolation valve that would shut off the water to the hot water taps is as circled in the photo at the top of the cylinder? (See photo)
If it is, is it as simple as putting on a hot water tap and shutting off this valve?
For cold water I was just going to shut off the cold water main below the sink.
Thanks for any help in advance,
Paul
Yes you’ve got it. Shut off the two valves you suggest and then open the taps that you wish to exchange. If a little water comes out and then all flow stops you are good to go, if it continues to flow at full blast - you need to look for other valves before you proceed.
But what you suggest should work.
Thanks!
Really appreciate the quick reply.
I’ll give this a go. Might be next weekend to do it but will feedback!
Reply to the thread, titled "Isolating hot water supply - indirect unvented cylinder system" which is posted in DIY Plumbing Advice on Plumbers Forums.
Paul0090,
Paul0090,
