View the thread, titled "Isolating valve" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Is it good practice what I'm planning to do. I want to drain the central heating and then put 2 isolating valves on the flow and return in readiness for when I purchase another radiator and that way after doing a little bit of pipework I can just top the system up. I want to drain now while the weather is warm and not do it when I'm freezing my nuts off.
I wouldn’t recommend the iso valves as there restrictive eg small bore either full bore or some lockshield gate valves
https://www.NoLinkingToThis/p/essen...15mm-lever-ball-valve-with-black-handle/8247v
Reply to the thread, titled "Isolating valve" which is posted in UK Plumbers Forums on Electricians Forums.
