View the thread, titled "Isolating valves on heat only boiler f & r pipes" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Captain.rick
Hi all,
as you may be aware im kinda new to this game. My mentor told me when fitting a heat only boiler he advises puting full bore isolation valves on flow and return pipes.
is this good advice?
cant see why not but dont see the point normally put comp couplings incase later on someone changes the boiler easy swap, but dont see the point in valves
Yes i guess he meant quicker for changes or boiler work.... But how often would that be?! I thought it would be better to drain a refill (fresh water & inhibitors) if work needed, but i guess for speed it could be beneficial?
Some argue compression = leaks etc
normally you change rad/rad valves when you take off / swap and as you have said new inhibitor etc
This is what i did, and some people are telling me I shouldn't have put them on flow?
well tbh somone could always turn them off thinking there somthing else and they might leak if in 10 years there used etc
aslong as there full bore and cant see anything wrong
Yeah i know what you mean, to be honest they are high up and the guy is very clued up on central heating boilers and systems so he knows what they are so thought he wouldnt mess. I can understand though... As a general rule should i bother? What would you do?
Thanks for all your advice by the way mate, I appreciate it
would i my answer no unless cus wanted them (dont see a point)
One guy said open vent are bot allowed valves between boiler and vent as could explode if valve closed... Wouldnt o/heat stat shut it down? Or would it expand that much?
thats what i said before 😉 and would expand that much
if its OV,cant fit valves,nowhere for the water to go if it vents over
It is open vented and my mentor knew it was too! Wow im shocked, im also embarrassed having to go back, what the hell can i say without making myself look stupid
just tell him there not rated for heating and your worried that they will leak and just remove them
makes you think, the same would apply to filters on the return and pump valves on the flow hmmmmmmmm 😀
Rick, what's the drain off after the valves for, surely that would be better placed under the boiler
The pipes come down from the ceiling and enter the boiler top right so rather than run pipe down and back up and round ( not much room in casing or cupboard its in) i just put it on the top
Reply to the thread, titled "Isolating valves on heat only boiler f & r pipes" which is posted in Boiler Advice Forum on Plumbers Forums.
