V
vetinry
Morning everyone
I am in the midst of renovating a property that we bought last year and (probably a little too late) am now considering options for the central heating and hot water.
Currently the house (approx 3000 sq ft, built in 1987) heating and hot water is supplied by an oil boiler (Boulter Camry 5?)
Heating
The central heating is "Y" plan and a single zone, and before we moved in, all rooms (14 of them) were supplied by radiators. There was insulation in the various loft spaces but I have been topping it up as and when there is an offer at B&Q - I'm aiming for min 300mm but it is actually deeper than this in some places.
We have already renovated the Kitchen and opted for Wet underfloor heating under a tiled floor and over 70mm insulation to achieve u-values.
Underfloor heating is not an option everywhere in the house because we want to put carpets and not have to worry about low tog values.
In one of the upstairs bedrooms, I am about to install skirting board heating to see how I get on with that.
And in the upstairs bathroom, we want to tile so we are considering either wet or electric underfloor heating.
Domestic Hot Water
The water is supplied by a cylinder, which I think I calculated as about 160litres and which seems to be a little bit small for a 5 bedroomed house.
In addition, the immersion heating is broken, and the cylinder is built into the eaves of upstairs making it's removal without removing the tank rather difficult.
In the upstairs loft, there are 2 huge water tanks (gravity system) and there are 3 shower pumps scattered throughout the house.
When the house was built, copper must have been pretty cheap because there are literally hundreds of metres of copper pipe running through the loft spaces. For example, each of the 3 showers are fed by their own 22mm supply and they are scattered throughout the house.
The hot water is also linked to a secondary circulation system due to the sheer distance that water has to travel to the various tap points.
I've checked mains pressure (about 4 bar) and flow (about 25 litres per minute)
Just before Christmas we had an oil delivery and 2500 litres at 75p per litres gave me a bit of a shock.
And now, I'm going to need a little bit more oil to get through the summer (boiler still supplying hot water)
Therefore I'm researching different options, principally to reduce our demand on oil and improve efficiency
Questions
I have some fairly basic questions which I hope you might be able to help with
How much of the oil is being used to heat the property vs hot water production.
Steve
Heating
Domestic Hot Water
Questions
- Is it very inefficient to have a DHW system which runs seperately from the CH. I've seen an indirect cylinder with built in air source heat pump which looks like it could supply all of my hot water at a fraction of the cost that I currently spend on oil
- If the oil boiler is on, does it make any difference whether it is heating lots of rooms or just a few? The reason I ask this is that I will still need to heat the underfloor heating, and rooms with carpets where radiators or thermal skirting will be used. But in the bathroom, for example, it would be much less expensive to install electric underfloor heating but if the boiler is already on, am I just spending twice on energy?
- Seperating the house into zones. I definitely want to zone off the kitchen ufh but wondered how close to the "centre" of the system the zone valves need to be placed. ie could you have the zone valves operating close to the rooms or is this inefficient since you are still heating pipework prior to the zone valves?
Steve
