Guest viewing is limited
I've got an extension!
View the thread, titled "I've got an extension!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
djboyd
Yes, my house is now bigger - so more rads. I've read that the normal max rads for a pump is 12 but I will have 13, including towel rails. The rooms are quite small so there are some small rads in that - all fed by 22mm branching to 15mm from an open vented system.
So, will my standard circulating pump be enough?
Thanks for any replies
I've got an extension too....and more rads.....and a 15/50 pump.....and 22mm pipe.....don't worry about it😉
i have 14 rads and runs fine off a combi, not sure which pump but if 22 and 15 should be ok
Reply to the thread, titled "I've got an extension!" which is posted in UK Plumbers Forums on Plumbers Forums.
djboyd,
djboyd,
