View the thread, titled "Jaguar 28kw Combi" which is posted in UK Plumbers Forums on UK Plumbers Forums.
R
rob jefkins
Hi guys,
Been looking at a problem on a Jaguar 28kw Combi for a customer. Heating works fine but does not fire up when hot water is called for.
I believe that the diaphragm in the divertor (diffrential) valve is probably shot away and needs replacing.
Any other thoughts from anyone?
Cheers
Rob
It would appear that this boiler is obsolete or is a dressup up version of a protherm boiler. Been looking for ages for spares for it and only found a couple.
Does anyone think that the flow switch would be at fault??
Hi guys,
Cheers
Rob
Think its the same boiler as a protherm , the diaghphram from a glowworm compact 80 will fit. its only £2 ish.
Reply to the thread, titled "Jaguar 28kw Combi" which is posted in UK Plumbers Forums on Electricians Forums.
