View the thread, titled "jambo" which is posted in UK Plumbers Forums on UK Plumbers Forums.
can some please explain an essex flange no funny answers plz
an essex flange is a tank connector you can fit from outside mostly used to add connections to cylinders where theres no way to insert a flanged tank connector from in side the flange is basicly oval and this pushes against a split washer that can be wound into the cylinder its easier than it sounds just dont let go till the nuts on
use a surrey flange, goes in the top and no dropping the nut.
+1 so much easier to fit., My missus is from Hornchurch in Esssex btw, unfortunatly its not true what they say about a girl from Essex🙁
Reply to the thread, titled "jambo" which is posted in UK Plumbers Forums on Plumbers Forums.
