View the thread, titled "Johnson Starley Economaire 32" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
diamondgas
Hi folks, anyone familiar with this fan flued warm air unit? I was asked today to check one out that's faulty. I have the mi's but the fault doesn't seem that straight forward.
On resetting the unit the flue fan kicks in, aps makes, ignition then pilot lights. It then attempts to light the main burner for the briefest of seconds and then the whole lot cuts out, display goes dead and no lockout lights ... Re-set and the same sequence occurs! At no time does the LED indicator display anything bar a little red light bottom corner! My hunch is the main control PCB but this is the first I've worked on and wondered if anyone on here has more experience with this appliance..
Cheers, Steve
Keepin it alive ......... got a call from the landlord who has decided to go to BG for repair 😛arty:
However I'm now curious and wondered if there was anyone with experience? I appreciate there are few who do warm air these days 🙂
Reply to the thread, titled "Johnson Starley Economaire 32" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
