View the thread, titled "Johnson & Starley Economaire 32" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Scotsnomad
We upgraded our J&S Warm air unit which was 30 years old and working fine but thought it advisable to get it replaced.
The installation took place on the 16th Nov 2012 and we sat back and reaped in the benefits or so we thought.
Shortly before Xmas the unit went pear shaped and failed. Our gas installation engineer had just been in for a hernia op so
was unable to assist us so we contacted J&S who sent an engineer who was in the area to assist us as it was still under
warranty. The unit had a fault in the window that indicated an absolute fault. The unit was repaired by replacing the defective
unit the engineer.
Today the unit has failed again, it has an 'absolute' failure again, I have attempted to reset it to no avail and have contacted both
my installation engineer and also J&S to get this sorted.
I am somewhat puzzled that this has now occurred twice in the two months we have had it and what are my rights
thanks for any suggestions/advice on this problem
For advice on rights then probably best on a civil rights forum or citizens advice or your lawyer rather than a plumbing forum. but if its under warranty then its Johnson and Starley's problem
Im not so bothered about the 'rights' aspect its more on rights regarding getting the whole unit exchanged if it continues to happen. The replacement cost me £3000 so its not a case of 'a recurring' problem.
I have contacted both J&S and the gas installer to get it remedied but what I would like to know is if this is a ongoing problem with the Economaire 32 system..
might help if you told us what the fault code is i doubt if it says absolute failure on the led screen the fault codes are available on the web and are probably in the paperwork your installer left
these are not that common any more so i doubt anyone here can say there's a known fault on this model and nothing jumped out at me on google i would just get the manufacturers back as they have repaired it once i would assume there were no installation faults
The fault indicated by a number '1' in the small window with a flashing dot in bottom right hand corner.
www. johnsonandstarley.co.uk / downloads /ZZ1088.pdf
You will find the crib for faults on page 18.... (You might have to take out the spaces as it wont allow me to post a url)
It seems that this problem may being caused by other issues, possibly the installation. Although the J&S engineer has not indicated such. Are you sure the unit and the plenum base its mounted on are correctly matched. (guessing its an up flow unit)? Don't normaly hear to many relability faults with J&S units.
It was an upgraded unit from the previous J&S which was very reliable just 30 yrs old.
I am with Reg Man - J & S units for us have all been fit and forget with never any comebacks
The J&S engineer attended on Friday and investigated the source of the problem. Initially it was believed to be caused by damp however when that was discounted and he investigated further it turned out that the Gas Installer left the 'orifice' ring in the flue. This is supposed to be removed when the flue is over a certain height which in this case it was (Over 5m). Hope this helps you in some way. Thanks for your response. Now I got to go and source a pump for the water circulation as Im getting water hammer lol...
How is a pump going to stop water hammer?
Surely you need a shock arrestor?
Sorry I might have picked up the term incorrectly. The boiler is heating the water through an indirect pipe in the combustion area and when it heats up the pipework starts a loud banging sound. I understood this term was called water hammer. The engineer who called the other day from j&S informed me that the problem would be resolved by installing a pump
So as said J & S units are OK when fitted properly - a bit like most things hey ?
So? was an installation fault. Cheer's.:hurray:
I have a unit from J&S, it was fitted after they advised the fitters it was the right unit, I don't know it was 20% less powerful (output) but they subsequently say it's more efficient and thus go... 1kw still is 1kw as far I know.
The unit has continually suffered from violent combustion, it lights with a bang. I now have lost count of haw many visits have been made to it..
At my wits end and J&S don't call or email when they say they will, I'm lumbered with a faulty unit that won't heat my house enough.
Reply to the thread, titled "Johnson & Starley Economaire 32" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
