A
a4drk
I'm in the middle of fitting a full bathroom.
Tiling / plumbing / electric under floor heating.
I've fitted a new towel radiator to the wall.
the existing pipes were 8mm micro-bore.
So, what I've done is raggled the wall & extended the pipes up the wall by using endfeed 8mm to 15mm - all hidden the pipes in the wall & then tiled over.
Drilled 2 perfect 16mm holes & the 15mm pipe pops tho.
Looks great....... however it doesn't work!
Brand new valves were used - they are Ok - i've taken them off - open / closed them - blew thro them.
The radiator bleeds OK - full of water.
What i thought was an airlock in the return ?
The house has 2 floors - upstairs has 2 bedrooms & this bathroom.
the 2 bedroom rads work OK.
How can i check the pipework on the return ?
I've not tiled the floor yet - not going to until this problem is solved.
Hope I've explained it well enough
any help would be much appreciated
Cheers
David
Uploaded with ImageShack.us
Cheers
David
