View the thread, titled "Kane 455 flue anaylser" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
mark_mc
what do you think of the kane 455 anaylser, i was going to buy this as my 1st anaylser for servicing and commissioning oil boilers.
i got a price of £697 inc vat that inculdes printer, smoke pump, commissioning kit guages
i looked at the kane 425 being using on u-tube and the only difference with the kane 455 was the 90 start-up
could you please give a bit of advice
Good analysers. Easy to use multifunction dial, rather than having search through menus. Think the only difference between the two is the 455 has better quality sensors that last longer between replacements. Think they have a 5 year life if I remember correctly.
455 uses an ir sensor i elieve which may be more reliable. I use a kane 250 bought a year old 2nd hand and it does the job fine, £80 plus vat to calibrate more each 2nd yr for sensor replaceents. Only problem being kane are useless at getting the kit back to you on time, promise its in the post when its still on the desk!! However, I cant see the point of multifunction machines as if you lose the gas sensor u lose the whole machine when its away being repaired. me i like a separate gas leak sensor, manometer, temp sensor and an fga in my bag. Didnt cost anymore but i will still have working kit if any is away being repaired. Plus you dont spend a fortune all in one go.
Is the 455 a manometer too? I have won one on eBay. Not sure what goodies the multi bit means! Gas leak sensor would be nice too.
Looking forward to getting it. Only went for a Kane because of advise from this forum.
Reply to the thread, titled "Kane 455 flue anaylser" which is posted in UK Plumbers Forums on Plumbers Forums.
