View the thread, titled "Kitchen hot water tap not working" which is posted in The Welcome Wagon :) on UK Plumbers Forums.
A
AB123456
Hi, I have just moved into my first home which has a Worcester combi 24cdi boiler. I have two plumbing issues which I would be grateful for some advice.
1. I get no hot water in the kitchen mixer tap unless the central heating is on. The toilet hot water works fine even without the central heating turned on. I recently increased the boiler pressure to 1.5 as it was below 1 - I am not sure if this has anything to do with it?
2. The central heating in my middle room is not working. I have bled the radiator and there was no air in there. The water pipes to the radiator are not warming up either.
Thanks in advance for your replies
Abs
Check both valves on the radiator are open, if they are, check the pin on the trv (if there is one).
Can you isolate the cold on the mixer tap?
Reply to the thread, titled "Kitchen hot water tap not working" which is posted in The Welcome Wagon :) on Electricians Forums.
