So no che k valve required?
Thanks would a check valve on the hot reduce the hot pressure/flow even more. Is already quite poor.
Thanks, what do you mean by see were water comes out the spout if different place then its ok?
Yes if it does it is not mixing in tap. Another way is fit tails to tap and take a mouth of water and blow it down each tail to see. Flow will be poor on hot as tap needs 0.3 bar 3 meter head of water and I bet hole in flexis is small.
Any advice please? I have always worked on new builds so been balanced supplies of a combi or unvented hot water with balanced cold.
Reply to the thread, titled "kitchen mixer tap check valve" which is posted in UK Plumbers Forums on Electricians Forums.
