View the thread, titled "kitchen tap has low pressure on hot water side." which is posted in Plumbing Advice for Any Other Country on UK Plumbers Forums.
obseen16
hi guys, i fitted a new kitchen sink a few months ago and the customer has come back to me this week saying the hot water pressure/flow is lower than it was. i went to look removed the flexi that was supplied with the tap - no blockage. checked the other sinks on the downstairs floor and they had pretty good pressure on the hot side.
he has a gravity fed hw system by the way. could this be a partial air lock or a faulty tap? cant think of any other reason for the pressure to be so poor, its not a trickle but its not as full flowing as the other hw taps in the house,
its quite a fancy looking tap so i dont think it was a cheap and cheerful one.
any ideas?
thanks
J
if your customer selected and bought the tap, tell them it is unsuitable for their system. that is not your problem and only changing to another type will resolve it. or its proberbly one of those low pressure taps with 10mm flexi pipe not 13mm, or water saving types with tight arse bore.
i come across them often.
ps. sometimes taking out the plastic anti-splutter thingy from the spout works.
Upvote 0
cheers redsaw, i tried taking out the anti splutter thing but it didnt do much, yes the flexis are those really thin 10mm types but what i dont get is why it had great pressure when i fitted it and now a few months later it doesnt? although i cant remember how good the pressure was originally im pretty sure its not anywhere near as good as it was. hmmm odd one. lol
Upvote 0
I have the same problem at home, but not my fault honest, she who must be obeyed went to her local church, IKEA, and found a tap she really liked, forced me to install it against my better judgement now the hot water only dribbles out, mind you I dont mind because it keeps her at the kitchen sink for longer!!
Regards
Mike
Upvote 0
totally in favor of woman at sink.
are you 100% positive its just the hot flow that has slowed over time??
if not check and clean the aerator at top of tap.
if you are then it ha to be a blockage/cal up on the hot pipe from boiler to tap
you can check the flow by removing the flex and pouring into bucket
agreed small flexibles are not ideal but if it worked before no reason why it should not work now
mild sulphuric acid is a good piipe cleaning acid for hard water areas
good luck
shaun
Upvote 0
cheers lads,
i cant remember it being really powerful when it was new so its probably just the customer thinking its got really bad when its actually not much different lol, think what i might do is swap the flexis over so the cold mains goes through the hot side and show the customer what happens, then ill change them back. im pretty certain its not an air lock or blockage. think its just the tap aint suitable for indirect gravity systems.
oh well. we shall see.
Upvote 0
Same for us, the kitchen tap is gravity fed and fitted with 10mm microbore.
http://www.*********.com/pj2/tap.jpg
Result?
Slow feed from the hot. And fast feed from the cold (mains)
http://www.*********.com/pj2/3.jpg
The 10mm microbore can be seen as copper tubes at the bottom.
Upvote 0
Reply to the thread, titled "kitchen tap has low pressure on hot water side." which is posted in Plumbing Advice for Any Other Country on Electricians Forums.
