N
nervous123
None of the pipework in my loft to/from my unvented cylinder has been lagged. I am looking to buy and fit the lagging myself. Some queries:
1. Most of the pipework is 22m (small section is 15mm). What wall thickness of pipe lagging do I need? 19mm, 25mm or more?
2. Is there any substantial advantage to buying a brand such as Armaflex over the pipe lagging available in Wickes or B&Q?
3. My 'brilliant' builder and his top quality 'plumber' fitted several of the pipes right next to each other (HW, CH and cold...):
I cannot fit pipe lagging onto any of the pipes as they are almost touching so was wondering what I should do instead. Should I buy reflective radiator foil, felt insulation, or something else? And should I try and wrap the hot pipes and cold pipes separately, or does it not matter if I wrap them all together?
Many thanks...
Many thanks...
