View the thread, titled "Leak from rear of water pump advice please" which is posted in Bathroom Advice on UK Plumbers Forums.
E
Evelina69
I have a performa 28 with a Grundfos U15 60 water pump fitted.
It yesterday developed a rather bad leak from what looks like the seal at the rear right of the pump body where it attaches to the copper pipe.
Do I need to replace the whole pump or can I just replace the seals. Is this a massive job?
if its on the pump unions then turn off the elctrics to the heating system close the to valves on the union and replace the washers. if its on the copper pipes goin into the unions then drain down the sytem to find out why the compreesion joint has failed.
If the pump unions are the gate valve type you should be ok
If the pump unions are the ballofix type, then drain down any way because the minute you turn the valves the usualy leak anyway
The leak is on the joint to the pipe that takes the water up into the burner is that makes any sense.
Photo below
[DLMURL]https://picasaweb.google.com/lh/photo/SH4IGL0ZzX-Pga_aJzxcsQ?feat=directlink[/DLMURL]
its time to get a plumber in, it may ell be that the joint just needs nipping up, but if you try, the nut and olive may come off the pipe causing a flood can you post some pics
Drain your primary heating circuit. Remove the pump body and check the O ring seals for damage. Clean any dirt from around the joints on both socket and spigot. Replace the pump body ensuring the pump is pushed fully home on the seals, secure with the relevant bolt.
Can I buy just the seals. I have tried a couple of places who want to sell me the complete pump
You need this O ring..Baxi is same as potterton. [DLMURL="http://www.gas-spares.co.uk/Catalogue/BAXI/BOILERS-Combi/105-COMBI-Range/105e-combi/O-RING-2"]O-RING - Gas Appliance Spares (Preston) Ltd[/DLMURL]
Reply to the thread, titled "Leak from rear of water pump advice please" which is posted in Bathroom Advice on Plumbers Forums.
