Hi all,
I hope you can help. I’ve recently moved into a property and have connected my washing pipe, and it’s washing fine, but leaving my under sink shelves soaked. I think it’s coming from the water source (pictured) and not the waste water pipe. It looks to be screwed on tight so not sure what’s causing it. The filter looks a little blocked but don’t know if that’s a factor? Would like to know if it’s an easy fix before I call someone out.
There’s no water coming out behind the machine itself.
Any help gratefully received, thank you!
