leak on a pushfit Tee
View the thread, titled "leak on a pushfit Tee" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
marsaday
I have used pushfit where before there was compression and the pushfit leaks. I intend extending the pipe using a connector (copper) and then use the push fit on the new copper.
Have you seen this happen before. I only have a little copper left to play with and dont want to cut it down even more.
Usually a leak from pushfit is caused by not having full slip into the fitting or a minute dent or scratch/score on the pipework can cause the seal on the O ring to fail. I prefer compression and soldered fittings than pushfit or Cuprofit which is a copper pushfit fitting.
Reply to the thread, titled "leak on a pushfit Tee" which is posted in UK Plumbers Forums on Plumbers Forums.
marsaday,
Guest123,
