Hi
I have a Potterton Performa 28, there is a leak from what I believe is the DHW valve, right at the front. There is water seeping from the pin in the center, the bit that operates the switch.
The hot water works fine but obviously there shouldn't be water leaking from it, I am correct in thinking it is the diaphragm that has gone?
If it is that, what would it likely cost to get it fixed, approximately.
Ed
Ed
