Hey, don't work on many Alpha's so could do with some pointers on this one I came across today...
It looks to be leaking from the connection onto the main heat exchanger at the bottom of the heat exchanger, is this a common problem? To get better access I'm going to remove the front combustion door & fan which will allow me to clean up the mess it's made in the combustion box.
i can't find the part number for a combustion door seal anywhere! I'm after the vaillant type door seal kit if anyone is familiar!?
