Phillay
Hi guys,
Looking for a solution to the following problem...
Called out to locate a leak from a bath with a mixer tap/shower installed. Only leaking when the shower is used, realised straight away that the mixer tap was loose (as in you could lift it a couple mm above the bath).
Explained that the tap nuts would just need tightening, then realised that the sealing washers had been placed between the backnut and the bath, as opposed to between the mixer and the bath...
So off I went, took the mixer off, cleaned the washers up (which were still in fine condition) and re-assembled with the washers in place directly under the tap.
Did the cold up nice and tight, but the hot has been a bit tricky... Basically, under the hot side, the base of the acrylic bath is not flat, more like a bridge, so the back nut is impossible to really tighten. I've got it done up nice and snug or as much as I feel I can without the potential of cracking the nut or stripping it's threads.
I'm guessing that could be the reason it came loose in the first place? that or the fact the washers got in the way of the backnuts? I've explained it to the customer, but if it comes loose or starts leaking again... what's the best way to get round it?
Cheers.
Cheers.
