View the thread, titled "Leaking close coupled toilet around base" which is posted in Boiler Advice Forum on UK Plumbers Forums.
PEE GROOVER
Hi can anybody help
had to change doughnut washer on downstairs loo. brought new washer and connector kit and assembled and checked for leaks with no problem. Noticed a small air bubble rising from bowl when you wee in it. have checked for blockages ect outside in main drain and ok. have noticed also urine around base of pan which has spread under vinyl flooring. Could this be a cracked pan.
thanks
mark
is there any sign of the toilet being cracked, for example a crack?
more likely to be leaking from a fitting/connection
or the problem is an issue with aim
my toilet has similar symptoms to yours, usually after my 10 year old son has used it
I've had this on a new pan. Couldn't find the crack but it was deffo broke
Good test is to fill pan. Mark level and check in a while to see of it has dropped
Thanks guys. I have a five year old and wondered if this is the problem. As a flooring contractor i have made sure that the vinyl has been properly sealed around the pan and skirtings ect. But still a mystery as the vinyl is soaking around pan area. You mentioned a pourus pan scotty what is this
Check the pan connector seal with the pan.
Do you have any dogs in the house? Un-neutered dogs in particular sometimes urinate against WC pans.
Isolate the cistern, flush and remove all water from the cistern with a sponge. Place off limits overnight and check around the pan in the morning.
feel around the back of pan for the close couple bolts, sometimes you get a drip coming off one or both bolts if the donut slips a bit when putting pan back on. add this to bad aim = big yellow puddle.
also feel round back of pan below the connector to soil pipe if that is wet then the pan connector seal has developed a leak (also possible during a donut washer change if pan gets nudged and not adequately secured.
will take 1 min to check this, if all good then isolate cistern and wait....as whpes says
Problem solved
On checking closley inside the pan there was a crack inside the toilet bowl and when the level had risen it would leak under the pan. have spent weekend fitting new pan and cistern and all ok. Cheers fellas for all the advice
Reply to the thread, titled "Leaking close coupled toilet around base" which is posted in Boiler Advice Forum on Plumbers Forums.
