I
Ian Noble
Hi all
I have had a very high water bill. When I turn the external stopcock off, the flow indicator stops spinning, so I assumed it was a house leak issue. However, I have noticed that the external stopcock is leaking. When the stopcock is turned off, the water to the house is turned off , the meter stops spinning and the stopcock stops leaking. When I turn it back on it leaks quite considerably and the flow indicator spins even though nothing in use. Wil I therefore being paying for leaking water from the stopcock which is directly next to the meter.
Thank you
Thank you
