solarCH
Has anyone experienced "leaking" on the new Ferroli Modena condensing boilers? We installed one this afternoon and liquid began seeping out from the bottom of the case via the gas tube. On opening the boiler we found that the tube which (probably) collects flu condensate is just stuffed into a plastic trap and the overflow level (seems) to be above the joint hight. In the attached photos you can see the trap and a drip near the joint.
The condensate tube is not blocked, if you blow into the tube the condensates seep out of the joint.. no condensate ever makes it out of the tube..
