C
clueless
Hello
I was hoping someone could help! We have a dual flush toilet with an internal overflow which is constantly dribbling. I have adjusted the screw which changes the level of the float and when you flush the toilet I see that the flow of water into the cistern apparently stops when the float reaches the right level. However, water must continue to trickle in very slowly because eventually it reaches the overflow pipe and trickles into the toilet pan.
What can I try next?
Any advice gratefully received.
Tracey 😕
Tracey 😕
