View the thread, titled "Leaking plastic manifold" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I live in a "multi occupancy building" A FLAT in old money.
The water supply to each flat is fed off a 4 way plastic manifold?
Where the supply to each flat is connected to the manifold, there is a slight/moderate leak.
The local water company is not interested so far, and a plumber has had a look and said this type of
piping is now obsolete, and he cannot repair it.
Are there any other avenues to explore?
I have posted some pictures in a large format here. http://tinyurl.com/gqbqrx3
Thanks.
The management company / agent for the building should be sorting it out.
And yes that type of plastic pipe is still available the problem is though it's not instant set glue for the joints, it needs time to set.
https://www.pipestock.com/abs/abs-pipe-fittings
It'll either have to be made up in advance and left to set or
it would be simpler to replace the fabricated manifold in copper.
There's more than 1 leak happening there.
No. I am only a resident.
I need to have the correct info. to present to the management, to avoid delaying tactics
cut back glue male iron and re do it in copper
or if you can re do it from stop tap
Reply to the thread, titled "Leaking plastic manifold" which is posted in UK Plumbers Forums on Electricians Forums.
