Leaking plastic part
View the thread, titled "Leaking plastic part" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I've had no problems with my boiler in the last 6 years. A couple of weeks ago it started slowly dripping from the plastic part shown in the picture. I have temporarily put a bucket underneath this and we've had to repressurise the boiler once.
Any ideas what this part is? It looks like I could tighten it, however with it being plastic, I didn't want to break it.
The boiler is a "BAXI Platinum Combi 28 HE" and is about 12 years old (at a guess from stickers on the boiler).
Many thanks
The dripping you can see may or may not be related to the leak that is causing your pressure to drop. Either way, I don't think this is a task a DIYer can legimately/safely tackle themselves. I'd start by asking the registered gas professional who normally services your boiler to assist.
have you had it serviced? If not I’d suggest you get it done as soon as possible, the part you point to is the condensate trap, it needs cleaning out as part of the annual service but only by a gas safe engineer as it’s part of the flue system.
it wouldn’t cause your boiler to drop pressure though, so maybe you have a different leak and it’s running out through this part of the boiler, either way I’d get a local guy to come check it out. These are fairly simple to work on, any issues should be easily rectified.
good luck pal 👍🏻
Reply to the thread, titled "Leaking plastic part" which is posted in UK Plumbers Forums on Plumbers Forums.
ashfp,
ashfp,
